#1 High Tensile Bolts
Posted: Sat Sep 01, 2018 11:26 am
by ALAN COCHRANE
Hi Everyone
Can anyone clarify whether hot oil dipping high tensile bolts alters their tensile strength.
The reason I ask is that I’ve just rebuilt a spare set of Girling 16P calipers for the GT6. As part of the rebuild I split the caliper bodies and replaced the internal O rings. The four bolts holding the two half’s together had some surface rust around the heads but were otherwise in good nick. I heated each one with a blowtorch until red hot and then dunked them in oil. They now look nice and black, but I’m now wondering if this was the right thing to do.
Alan
Alan
#2 Re: High Tensile Bolts
Posted: Sat Sep 01, 2018 12:20 pm
by JagWaugh
You've hardened them. Hardening also makes them more brittle.
Buy new bolts.
Get a bottle of gun blacking. Or Google "DIY Parkerizing".
The formula I use is pretty much this: https://www.milsurps.com/showthread.php?t=43247
Parkerising is dead easy.
#3 Re: High Tensile Bolts
Posted: Sat Sep 01, 2018 2:31 pm
by ALAN COCHRANE
Thanks for the info. I suspected this was the case.
I now have the option of nickel plating as well since buying a kit online. I’ll swap the bolts out of the existing callipers and use them if they’re in gods nick.
Alan
