Alternator with fried connector
elliottS
#1 Alternator with fried connector
Post by elliottS » Tue Sep 04, 2018 10:50 pm
Searching why my ignition light will not come on with ignition sw. Found the connection on the alternator which is the main power with a hefty wire is connected. It had become very hot the rubber cover was melted the the brown insulator piece was burn't in half. This one is in the plastic holding the brushes. I don't know where to go to get parts. I installed a rebuilt alternator and might have put in on such it shorted and burn't.
Elliott Stage
1969 FHC
Silver
#2 Re: Alternator with fried connector
Post by mgcjag » Wed Sep 05, 2018 7:37 am
Hi Elliott..check with the usual suppliers...last time i replaced alternator bushes i got them with the plastic holder.. Steve...edit.....just looked at SNGB it shows as no longer available.....you will need to search for Lucas Brush Box Assembly.........for the alternator model you have
JagWaugh
Switzerland
#3 Re: Alternator with fried connector
Post by JagWaugh » Wed Sep 05, 2018 7:39 am
The alternator is also pretty close to the exhaust headers. Do you have a heatshield installed?
