Camber and Castor Gauges
#1 Camber and Castor Gauges
Post by christopher storey » Sun Nov 29, 2009 9:20 am
Can anyone tell me where you place a castor gauge to measure the angle ( S1 E type ) please? The workshop manual is silent on this
Post by Heuer » Sun Nov 29, 2009 1:12 pm
Christopher
Depends which tool you are using but ideally it will fix to the wheel hub with the spinner removed. Bear in mind you will need to move the wheels left and right 20 degrees so a turntable (or some care) is required. Other option is to do it with the wheels off the car but that means loading the suspension. Here are the instructions for the Seeley tool which may help:
www.justoffbase.co.uk/pdf/ins/GA45.pdf
daverawle
#3 Re: Camber and Castor Gauges
Post by daverawle » Sun Nov 29, 2009 3:25 pm
christopher storey wrote:Can anyone tell me where you place a castor gauge to measure the angle ( S1 E type ) please? The workshop manual is silent on this
Christopher,
for castor I found it easier to take it to an alignment shop - once you have the measurement for each side mark the fulcrum shaft then each full rotation of the shaft changes the castor by 0.4 deg.
1963 OTS
Post by christopher storey » Sun Nov 29, 2009 6:55 pm
Thanks to both Davids for that very useful information. I have to say I find suspension work some of the most difficult things to do on an E
Dave K
Post by Dave K » Fri Dec 04, 2009 5:47 pm
Christopher,
I have some photos of mine when I done it in my garage. I used the correct Dunlop gauges with the turntables.
I don't know how to post photos so can't show you.
Dave[/u]
