#1 Half shaft UJ`s
Posted: Thu Nov 29, 2018 8:03 pm
by Nigel GT
Hi Guys,
I am changing the half shaft UJ`s, I have one fitted at the moment, in one axis I have easy movement by hand and in the other axis it has stiff movement by hand, what should I be aiming for?
Nigel
#2 Re: Half shaft UJ`s
Posted: Fri Nov 30, 2018 1:44 am
by Geoff Green
Nigel,
You want easy in all directions. You have a cap too far in and need to move out, perhaps 0.001" is enough. Leave the clips in and smack the axle towards and inline with the stiff plane of the joint. Hold by hand and use the knock off hammer on the other side of the joint. May need to rotate 180 degrees and do again to be sure both caps are not pressing on the ends of the center cross of the u-joint.
#3 Re: Half shaft UJ`s
Posted: Fri Nov 30, 2018 9:56 am
by Nigel GT
Thanks Geoff for your advice, I give it a go.
