#1 Front right indicator dead / help needed
Posted: Sat Jan 05, 2019 10:25 pm
All,
I am now putting the front electrics back together, and I have it all working - except for the front right indicator.
Front left indicator is alive via a green cable with a red stripe, front right should be green with a white stripe (I guess).
Now, where is the indicator relay - I think under the dashboard ? It cannot be fuse 7, because the other side works - there are several pure green wires heading left, I checked them all.
It cannot be the switch - rear both are working.
I also found that the additional hazard flasher does not work - if I flip up the switch, nothing.
Can anyone shine some light on this - where to look next? I think that I should start at the indicator relais, if something‘s coming out there, or not.
Carsten
Carsten
