Rear wishbone seat damage
simong
#1 Rear wishbone seat damage
Post by simong » Thu Jan 24, 2019 9:08 pm
I am in the process rebuilding the IRS and diff and have the unit out of the car and dismantled. Most parts are not too bad, the diff is being sent off for rebuild, however the rear inner wishbone bearing seats are damaged on both wishbones, the photo shows the damage. My question is what can be done? My initial thoughts are to have bearing seats professionally bored and sleeved, I would think all four would have to be done in order to ensure the correct alignment.
Any thoughts, alternative ideas and any recommended companies who could carry the repair work would be much appreciated.
1969 S2 2+2, 1974 MG Midget
#2 Re: Rear wishbone seat damage
Post by 1954Etype » Thu Jan 24, 2019 10:07 pm
An alternative solution is to go for phosphor bronze bushes. The arm could be machined out and bushes made to fit. I have them in my car and after about 30k miles, they still work well.
Quattrofrank
Norway
#3 Re: Rear wishbone seat damage
Post by Quattrofrank » Thu Jan 24, 2019 10:20 pm
+1 for the bronze solution. Or you can buy a pair of undamaged arms, probably the best solution to get it 100% correct
Robbiee
#4 Re: Rear wishbone seat damage
Post by Robbiee » Fri Jan 25, 2019 7:09 am
Hi Simon
I might have a pair in my garage you can have
I’ll photo them and send a picture
Roy
simong
#5 Re: Rear wishbone seat damage
Post by simong » Fri Jan 25, 2019 8:55 am
Hi all,
Thanks for your replies.
Angus - are these bushes available 'off the shelf' and as over sized or would they have to be custom made?
Robbie - please let me know the details and what you want for them.
Many thanks
#6 Re: Rear wishbone seat damage
Post by 1954Etype » Fri Jan 25, 2019 10:28 am
Hi SImon, the standard ones are off the shelf. Yours would have to be custom made.
Angus
Robbiee
#7 Re: Rear wishbone seat damage
Post by Robbiee » Fri Jan 25, 2019 2:20 pm
Hi Simon
I’m not sure they’re the correct type/dimension for you
I’ve stuck a tape measure next to them to see
You can have them for £50
If they’re the correct size I’ll press out the bearings and see if they’re ok
Robbie
Robbiee
#8 Re: Rear wishbone seat damage
Post by Robbiee » Fri Jan 25, 2019 3:07 pm
I’ve pressed out the bushes and the bore looks pristine(see photo)
Don’t be put off by apparent rust/mud/oil..the wishbones are fine
simong
#9 Re: Rear wishbone seat damage
Post by simong » Fri Jan 25, 2019 3:44 pm
Hi Robbie,
They are the same size as mine and will be fine after a good clean! I will drop you a PM to arrange pick up etc, I am based in Notts so not too away.
#10 Re: Rear wishbone seat damage
Post by mgcjag » Fri Jan 25, 2019 5:19 pm
Great example of what this forum is all about.....helping each other...well done all :bigrin: Steve
Jeremy
#11 Re: Rear wishbone seat damage
Post by Jeremy » Fri Jan 25, 2019 5:38 pm
:yeahthat:
Jeremy
1967 S1 4.2 FHC
