#1 Splined Yoke
Posted: Wed Feb 13, 2019 11:09 pm
Hi All....Splined yoke that fits into rear hub....No 26 on SNG https://www.sngbarratt.com/uk/#!/Englis ... UM%20SHAFT shown as no longer available...a friend needs a replacement due to damage removeing it....are they E type specific or interchangable for those used on XJ6 (S1/2/3)....I know that the splines are the same as the rear hubs and bearings are the same but is the overall length and part that connects to universal joint the same.....will also get him to post in wanted section...thanks..Steve
#2 Re: Splined Yoke
Posted: Thu Feb 14, 2019 1:20 am
AFAIK they are interchangeable. The length difference is in the central driveshaft section.
#3 Re: Splined Yoke
Posted: Thu Feb 14, 2019 9:08 am
Hi Andrew...thanks for the reply....will get one and check it out...all the best...Steve
#4 Re: Splined Yoke
Posted: Thu Feb 14, 2019 10:37 am
Steve : wire wheels were never offered as an option in XJ6 cars, so that I'm afraid is likely to be a non-starter. Your best bet is S type/420/Sovereign up to 1968/9, which may be the same . What is the nature of the damage ?
#5 Re: Splined Yoke
Posted: Thu Feb 14, 2019 11:39 am
Hi Christopher its just the splined yoke....not the hub.....im currently useing xj6 splined yoke on e type rear splined hub on my C type build so i know they fit just not sure they are the same part as on E type....the damage was caused by a garage trying to press out the splined shaft.....the hub carrier cracked and the thread end totally crushed....dont have exact details as im a 3rd party.......the forum member with the problem will add more detail here i think.....iv supplied a replacement hub carrier....just trying to get him sorted with parts to continue his rear end refurb...Steve
#6 Re: Splined Yoke
Posted: Thu Feb 14, 2019 12:22 pm
by Robbiee
I have a couple of these from an Etype rear axle that are in good Nick (need cleaning/paint) if you want them
Just PM me
Robbie
#7 Re: Splined Yoke
Posted: Thu Feb 14, 2019 2:09 pm
Hi Robbie...thanks for the offer....im only acting a 3rd party to help....Im sure Andy will post here soon and update progress....all the best...Steve
#8 Re: Splined Yoke
Posted: Thu Feb 14, 2019 2:48 pm
by ClassicJagMan
Hi Andrew, Christopher, Robbie (and Steve),
My name is Andy, Steve (mgcjag) very kindly posted the original post on the forum on my behalf. He has been very kindly spending a lot of time in helping me trying to sort out my predicament. The story so far..........My E-type is currently in a garage having the rear cage overhauled with new discs, callipers, shocks, springs, bearings etc., etc., The garage was unable to separate the splined yoke from the splined hub, on the offside, despite applying up to 30tons of pressure in a hydraulic press! Unfortunately whilst trying the aluminium hub carrier cracked under the pressure before the shafts even budged a millimetre and the short splined yoke was damaged beyond use. Steve has supplied me with a replacement hub carrier which has left me trying to source a replacement splined yoke. As mentioned by Steve above, SNG show the part as not being available as it is no longer manufactured. That is my current state of play.................
Robbie, I am extremely interested in your offer and have sent you a PM, this could finally resolve all my woes........fingers crossed.
I would just like to say how much I really appreciate all of your collective advice and help in trying to assist me resolve my dilemma, this is such a great forum.
Many thanks again to all of you.
Kind regards,
Andy
#9 Re: Splined Yoke
Posted: Thu Feb 14, 2019 2:52 pm
by fj55mike
I recently went through similar woes and ended up needing to replace my splined yoke. I called around and Welsh Enterprises in Ohio had several used ones on hand, at a reasonable price. Good luck,
MB
#10 Re: Splined Yoke
Posted: Thu Feb 14, 2019 2:58 pm
by ClassicJagMan
MB
Many thanks for the info Michael, I will bear that in mind.
#11 Re: Splined Yoke
Posted: Fri Feb 15, 2019 11:10 am
by angelw
Hello Andy,
This reply is not going to help you much to get a replacement splined yoke, other than I'm fairly sure that one from an XJ6 is the same (from the universal outwards). However, this may help others that are yet to tackle the dismantling of the rear hub from splined shaft, to have some clue as to how it comes apart. If the aluminium hub was damaged during the process, then the garage doing the work had not a clue how.
There should be no pressure whatsoever on the aluminium hub carrier, at any point in the process. The effort needs to be confined to the two parts being separated and that was clearly not the case if the hub carrier was damaged, I'd say that was one reason for the 30ton load; not all of that load was being applied to the parts to be separated. It was quite common, at one time, to Loctite this spline. Even the gnarliest of splined shaft and hub, I've not got anywhere near 30tons.
Picture Hub3 following shows my rig in place ready to press the splined shaft from the hub. The Hub Carrier and all other parts are suspended below the plate. Only the threaded end of the hub is protruding through the plate and is held captive by the Threaded Boss (Left and Right Hand Threaded). The centre pin engages with the centre drilled hole of the splined shaft. Accordingly, pressure applied to the pin will tend to push the splined shaft down, through the internal spline of the hub (which is held stationary).
Hub3
Picture Hub1 following shows the threaded boss supported on timber spacers. This is for demonstration only, so that the arrangement of the hub coming up through the plate can be seen.
Hub1
Picture Hub2 following better shows the arrangement of the centre push mandrel.
Hub2
The Threaded Boss in my pictures is quite similar to the tool specified by Jaguar (Tool JD7A). JD7A has a couple of holes around it's circumference for a Tommy Bar, and a centre threaded hole for a jacking bolt. My interpretation, is their tool on steroids.
#12 Re: Splined Yoke
Posted: Fri Feb 15, 2019 11:23 am
Hi Bill..thats a great tool but unfotunatly must of us diy guys dont have the facility to make one so pressing the shaft while supporting the hub carrier is something we have to resort to.....most times you will seperate the splined yoke but there is always the chance of damaging the carrier....that said there is no real excuse for a garage not doing the job properly..
Looking at your tool i was wondering if a continental style spinner with a hole drilled in the center could work in substitute of the main body of your tool......screwed on to the hub and supported from below just as yours above and use a press through the hole onto the shaft.....your thoughts for us diy guys.....Thanks...Steve
#13 Re: Splined Yoke
Posted: Fri Feb 15, 2019 12:08 pm
by angelw
Hello Steve,
Yes, that would work. I've seen spinners (both Eared and Continental) drilled and threaded in the centre to facilitate a jacking bolt. The limiter with the jacking bolt version is the amount of force that can be applied with the threaded jacking bolt. Accordingly, there is no reason why a plain centre hole and a good fitting pointed mandrel would not work well with a press. Clearly, more force could be applied with my steel unit, but the arrangement would be the same and all the force would be applied to the parts that you want to separate. However, the modified spinner would be capable of withstanding the load required to separate a really stuck assembly.
#14 Re: Splined Yoke
Posted: Fri Feb 15, 2019 1:22 pm
Hi Bill thanks for the reply....is your last sentance correct....or should it be ...would not.....thanks Steve
#15 Re: Splined Yoke
Posted: Fri Feb 15, 2019 2:07 pm
by angelw
Hello Steve,
The sentence as written is correct. Using the Spinner in the same manner as my set up puts the load on the threads, which would be in shear. The Spinner used in this manner would be stronger than used with a centre threaded hole and a jacking bolt. I believe that the area around where the thread would be cut in the centre, would be the weakest part of the Spinner set up.
#16 Re: Splined Yoke
Posted: Fri Feb 15, 2019 11:17 pm
by ClassicJagMan
Hi Bill & Steve,
Many thanks for your recent posts. The contents of which I found very interesting and have duly noted.
Kind regards,
Andy
#17 Re: Splined Yoke
Posted: Mon Feb 18, 2019 1:11 am
by ClassicJagMan
UPDATE................
This great forum has come up trumps yet again!
A very kind member, Robbie (Robbiee) has sent me a replacement splined yoke. Hooray!
Many thanks for everyone's contributions and advice, especially to Steve (mgcjag) & Robbie (Robbiee) for supplying me with the necessary aluminium hub carrier & aforementioned splined yoke.
I am so happy that my rebuild/restoration is back on track once more.......................
Kind regards,
Andy
#18 Re: Splined Yoke
Posted: Mon Feb 18, 2019 5:59 am
I just want Bill's workshop. 2 sandblasting cabinets next to each other? Oh yeah!
#19 Re: Splined Yoke
Posted: Mon Feb 18, 2019 9:58 am
by ClassicJagMan
HaHa Andrew, I couldn't agree more! :thumbsup:
