Series 1.5 wiper motor
Tricky1.5
#1 Series 1.5 wiper motor
Post by Tricky1.5 » Tue Feb 19, 2019 11:37 pm
I’m looking to replace the wiring loom in my series 1.5. The DL3A wiper motor is unique to this model and only has 3 wires plus an earth. Can anyone tell me if the original wiring loom for the 1.5 has 3 wires or did jaguar install the standard 5 wire loom and just not use a couple of wires.
Cheers,
1968 series 1.5 FHC
#2 Re: Series 1.5 wiper motor
Post by Heuer » Tue Aug 06, 2019 1:36 pm
The DL3a wiper motor was indeed only fitted to S1.5 USA LHD cars which is a shame because it is a far better solution than the DL3 because the park control is on the motor itself and can be adjusted easily. No problem in converting it to RHD parking as you just need to rotate the paxolin disc on the gearbox 180 degrees.
All the information you need should be here: http://forum.etypeuk.com/viewtopic.php?p=20530#p20530
