8103 and 8107 sealing washers - valves on oil filter head
rfs1957
#1 8103 and 8107 sealing washers - valves on oil filter head
Post by rfs1957 » Thu Aug 08, 2019 4:08 pm
I touched on these here
http://forum.etypeuk.com/viewtopic.php? ... 03#p116995
and am putting them in this separate post to make them easier to search for.
Couldn't find any usual suspect who stocked them as Jag parts.
However, smaller one (8103, under the balance valve) can be replaced by 20mm x 24mm x 1.5mm, as is, and the larger one (8107, under the relief valve adapter) by 22mm x 27mm x 1.5mm which just needs about 0.3 taking off the OD, both available from GWR Fasteners - SY11 4AD.
Bought five of each so if anyone wants a pair speak up and they can have them for free in the post.
