Hi,me again,there are two small pipes,going from the inlet manifolds,to either side of the header tank,one broke off,as soon as I touched it.what is the easiest way to change them?Drill them out?Heat?Are new ones available,or just a bit of tube?Best way to secure them?
Thanks for looking.
Water/Bleed Pipe S3
#1 Water/Bleed Pipe S3
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
65 Austin Healey 3000
66 Scimitar Coupe
He who dies with the most toys wins.
07 Vanquish S
07 Vantage Roadster
66 Scimitar Coupe
#2 Re: Water/Bleed Pipe S3
Hello Neil,
I may have had a similar problem...Drilled & tapped for a new BSP barb. Replaced with a new section of hose. Hope the photos help.
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
#3 Re: Water/Bleed Pipe S3
Magic,thanks for that.
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
66 Scimitar Coupe
07 Vanquish S
07 Vantage Roadster
66 Scimitar Coupe
