#1 series 2 oil filter gasket / o ring size
Posted: Sat Mar 30, 2019 7:54 am
by JOHN HAY
Hi , does anyone know the size of the oil filter rubber gasket? I have 2 different thicknesses, not sure which one to use.
John.
#2 Re: series 2 oil filter gasket / o ring size
Posted: Sat Mar 30, 2019 8:59 am
Hi John...the one that fits the best...make sure you remove the old one....Steve
#3 Re: series 2 oil filter gasket / o ring size
Posted: Sat Mar 30, 2019 9:33 am
by JOHN HAY
Hi Steve, thanks for your reply, have tried the thinner of the 2 which fits best, but it still leaks, perhaps I have over tightened the bolt?
#4 Re: series 2 oil filter gasket / o ring size
Posted: Sat Mar 30, 2019 10:31 am
Did you replace the felt and rubber washers on the canister?
#5 Re: series 2 oil filter gasket / o ring size
Posted: Sat Mar 30, 2019 10:50 am
by 1954Etype
Are you 100% you removed the old one?
#6 Re: series 2 oil filter gasket / o ring size
Posted: Sat Mar 30, 2019 2:49 pm
by JOHN HAY
Yes guys, replaced the felt washer and the rubber one, skimmed the bottom of the canister, but not sure which o ring to use.
