Diff o/p shafts
Topic author - Moderator
#1 Diff o/p shafts
Hi All....just a heads up for anyone removing their diff o/p shafts for new seals etc...beware they are handed...I marked mine befor removing but thought both sides were the same...just found out that the gap between the bolt hole for the caliper and the bolt hole next to it are different spacing top and bottom...you want the smaller space at the bottom...get it wrong and it affects the angle the caliper is mounted at...Steve
