Adhesive number plate
paustin
#1 Adhesive number plate
Post by paustin » Tue Apr 23, 2019 5:56 pm
After repaint I'm about to apply adhesive plate to the bonnet. It's been a few years since I did one and wonder if applying soapy water to area so as to slide plate into place while squeezing out any bubbles/rinkles is still best practice?
#2 Re: Adhesive number plate
Post by cactusman » Tue Apr 23, 2019 7:19 pm
Might depend on what sort of adhesive they use....others will know.....
#3 Re: Adhesive number plate
Post by mgcjag » Tue Apr 23, 2019 7:49 pm
Hi Phil....see similar topics shown below.....http://forum.etypeuk.com/viewtopic.php?f=2&t=3926
johnetype
#4 Re: Adhesive number plate
Post by johnetype » Wed Apr 24, 2019 7:59 am
Soapy water worked well for fitting mine a year ago.
1969 Series 2 FHC
#5 Re: Adhesive number plate
Post by Heuer » Wed Apr 24, 2019 9:19 am
Windscreen or window cleaner (spray type) works well because it does not leave a residue and evaporates fairly quickly. Soapy water does the opposite!
nefematic
#6 Re: Adhesive number plate
Post by nefematic » Wed Apr 24, 2019 9:26 am
There exists a note of how far up from the air intake the plate should sit. You might want to check for that measurement before fixing it in place. I couldn‘t pull it up just now. If I find it I‘ll post it.
Martin Scherz
Late S2 1970 OTS US LHD
Simonpfhc
#7 Re: Adhesive number plate
Post by Simonpfhc » Wed Apr 24, 2019 12:02 pm
+1 on the window cleaner - it worked perfectly on mine. There were a few tiny bubbles left that I couldn’t quite squeeze out, but a few months later they all disappeared. Leaving it in the sun really helped with removing these.
I think the measurement is about 6” up from the front of the nose. This leaves the plate equidistant between the bonnet bulge and the nose.
Cheers.
62 3.8 FHC
91 Porsche 928GT
#8 Re: Adhesive number plate
Post by Heuer » Wed Apr 24, 2019 12:35 pm
nefematic
#9 Re: Adhesive number plate
Post by nefematic » Wed Apr 24, 2019 1:28 pm
That‘s the one I meant David! Thanks.
Martin Scherz
