#1 Adhesive number plate
Posted: Tue Apr 23, 2019 5:56 pm
by paustin
After repaint I'm about to apply adhesive plate to the bonnet. It's been a few years since I did one and wonder if applying soapy water to area so as to slide plate into place while squeezing out any bubbles/rinkles is still best practice?
#2 Re: Adhesive number plate
Posted: Tue Apr 23, 2019 7:19 pm
by cactusman
Might depend on what sort of adhesive they use....others will know.....
#3 Re: Adhesive number plate
Posted: Tue Apr 23, 2019 7:49 pm
Hi Phil....see similar topics shown below.....http://forum.etypeuk.com/viewtopic.php?f=2&t=3926
#4 Re: Adhesive number plate
Posted: Wed Apr 24, 2019 7:59 am
by johnetype
Soapy water worked well for fitting mine a year ago.
#5 Re: Adhesive number plate
Posted: Wed Apr 24, 2019 9:19 am
Windscreen or window cleaner (spray type) works well because it does not leave a residue and evaporates fairly quickly. Soapy water does the opposite!
#6 Re: Adhesive number plate
Posted: Wed Apr 24, 2019 9:26 am
by nefematic
There exists a note of how far up from the air intake the plate should sit. You might want to check for that measurement before fixing it in place. I couldn‘t pull it up just now. If I find it I‘ll post it.
#7 Re: Adhesive number plate
Posted: Wed Apr 24, 2019 12:02 pm
by Simonpfhc
+1 on the window cleaner - it worked perfectly on mine. There were a few tiny bubbles left that I couldn’t quite squeeze out, but a few months later they all disappeared. Leaving it in the sun really helped with removing these.
I think the measurement is about 6” up from the front of the nose. This leaves the plate equidistant between the bonnet bulge and the nose.
Cheers.
#8 Re: Adhesive number plate
Posted: Wed Apr 24, 2019 12:35 pm
#9 Re: Adhesive number plate
Posted: Wed Apr 24, 2019 1:28 pm
by nefematic
That‘s the one I meant David! Thanks.
