#1 Broken window frame
Posted: Mon May 13, 2019 3:33 pm
by Bernie2015
The chrome window frame is broken in half on my Series 3 (see photos). Has anyone seen this before and any thoughts on how to repair it.
#2 Re: Broken window frame
Posted: Mon May 13, 2019 3:44 pm
Hi Bernie...cant make out much from you photos.....stand back a bit and take a couple....is it just broke in one place?... Steve
#3 Re: Broken window frame
Posted: Mon May 13, 2019 4:15 pm
by Bernie2015
Yes just broken in half where it slots into the door panel
#4 Re: Broken window frame
Posted: Mon May 13, 2019 4:17 pm
by Bernie2015
#5 Re: Broken window frame
Posted: Mon May 13, 2019 4:18 pm
by Bernie2015
The previous owner had riveted a piece of aluminium plate to hold the pieces together but obviously it didnt work
#6 Re: Broken window frame
Posted: Mon May 13, 2019 4:50 pm
Hi Bernie..ok so ..am i right in thinking its an ots and not a "frame" like on the 2+2 but the front upright channel?... would suggest a small engineering shop to see if a weld or braze would sort it...then possibly re chrome if needed....work out befor you take it in if there is enough room for a reinforcment plate.....Steve
#7 Re: Broken window frame
Posted: Mon May 13, 2019 5:37 pm
by Bernie2015
Yes that's right Steve its just the front upright part of the window on my Series 3 OTS
#8 Re: Broken window frame
Posted: Tue May 14, 2019 7:33 am
by MarekH
It is one part of a large chrome "H" structure which bolts into the bottom of the door. You'll have to dismantle the entire door insides to retrieve it . Then you can decide what to do with the two pieces, assuming spares are not readily available.
#9 Re: Broken window frame
Posted: Tue May 14, 2019 10:56 am
by Bernie2015
Thanks Marek
