#1 Dynamo
Posted: Sat Jun 08, 2019 10:53 am
by Robbiee
Dear all
My March ‘62 has a replacement dynamo part number 22910 with a date of 11-68 (I can’t see if it’s a C42 or not)
I understand that it should have a number 22902 /C42
My questions
1. Do I get the one I have restored and, if so, would it work ok for my car?
2. Should I try to find a 22902 of an earlier type ?
Robbie
#2 Re: Dynamo
Posted: Sat Jun 08, 2019 11:37 am
The C42 dynamo's were all numbered 229xx with differences being mounts and connectors amongst other internal items. You can check through the various Lucas catalogues in the Knowledge Base if you want more information but if it fits then go ahead and use it. The C42 fitted to the E-Type was actually numbered 22902A/B.
By 1965 the only cars which had them were the Mk2 and 'S' models with variances depending whether power steering was fitted.
#3 Re: Dynamo
Posted: Sat Jun 08, 2019 2:54 pm
by Robbiee
Thanks David
It came fitted to the car and so I’ll get it reconditioned locally and use it...I was thinking about a dynamator or such like but it’s a lovely original early car so I’m going to stay with the dynamo(maybe change to neg earth)
Robbie
#4 Re: Dynamo
Posted: Sat Jun 08, 2019 3:09 pm
Yes, changing to -ve earth is sensible and easy; vital if you intend using a SatNav or phone charger. There is a conversion guide in the Knowledge Base.
#5 Re: Dynamo
Posted: Sat Jun 08, 2019 6:11 pm
by Robbiee
Great thanks
#6 Re: Dynamo
Posted: Mon Jun 10, 2019 9:32 pm
by Robbiee
Can anyone tell me if my dynamo pulley is the correct diameter please?
3.8 1962 R4095
C42 Dynamo
My Pulley is 3.5 inches diameter
See photos
Robbie
#7 Re: Dynamo
Posted: Mon Jun 10, 2019 9:33 pm
by Robbiee
Should be C18227
#8 Re: Dynamo
Posted: Wed Jun 12, 2019 5:07 pm
by Robbiee
Hi again
Can I jog someone to help me with my dynamo pulley question (see above)??
Robbie
#9 Re: Dynamo
Posted: Wed Jun 12, 2019 6:35 pm
by Nawang61
#10 Re: Dynamo
Posted: Wed Jun 12, 2019 6:45 pm
by Robbiee
Mine has the slightly earlier March '62 single groove
It looks like my pulley is in the right ball park for diameter
Robbie
#11 Re: Dynamo
Posted: Wed Jun 12, 2019 9:03 pm
by ALAN COCHRANE
Robbie
I've just measured mine and it's 3&1/8" in diameter and single groove.
When I bought my car in 2011 it was running with a Lucas 11AC alternator and this size of pulley wheel brazed onto the front. I discovered that this was because the shaft of the original dynamo is slightly wider than the equivalent on the alternator and this setup was cobbled together to keep running with the single V fan belt.
I subsequently found another pulley wheel of the same diameter that fitted directly onto the alternator.
Apologies for the long winded answer.
Alan
#12 Re: Dynamo
Posted: Thu Jun 13, 2019 6:03 am
by Robbiee
Hi Alan
My car is March 23rd 1962 build. RHD 850456...so not far off yours
Thanks for the reply
Robbie
#13 Re: Dynamo
Posted: Thu Jun 13, 2019 12:45 pm
by MarkRado
Hi Robbie,
sorry for my delayed reply. My dynamo has a date code of 62, but the car is late 63, so obviously neither matching nor original. I got tired oiling and replacing the rear bearing bush (receiving exessive heat from the exhaust manifold esp on long highway journeys) again and again. I already had made up a custom heat shield, but instead of searching for a matching replacement plus restoration, I replaced it with an alternator-dynamo lookalike called dynamator (using the orig pulley). Not expensive and definitely an improvement regarding output esp at low revs/ around town. Lets see how many years it will last...
#14 Re: Dynamo
Posted: Tue May 16, 2023 8:36 am
by PierreW
MarkRado wrote: ↑Thu Jun 13, 2019 12:45 pm
how long did he last?
#15 Re: Dynamo
Posted: Tue May 30, 2023 11:09 am
by MarkRado
Still working
#16 Re: Dynamo
Posted: Wed Jul 02, 2025 1:20 pm
by Tony
Mark, what model Dynamator did you go for. What the difference between a C42 and C45 Dynamator.
I am going for a Dynamator as I fed am up going through regulators. I am on my third one so far and find them unreliable.
Tony
