Hi all,
I am looking for a clutch hose for my 420G project. Looking up/ ordering by the spares number from the parts catalogue returns the wrong part. Unfortunately our local hose shop does not have the required fittings in stock. Any recommendations where to buy?
Thank you
bespoke clutch hose
#2 Re: bespoke clutch hose
Hi Mark..plenty of places to have brake and clutch hose made just google search.....what is it actually for is it a 420G.....or are you useing a 420 engine in a E type....whats different in your setup to an E type?....what part number have you looked up......here is one company i have used to make hose,s Steve https://brakequip.co.uk/?gclid=EAIaIQob ... gI--_D_BwE
#3 Re: bespoke clutch hose
Hi Steve, it is indeed for a 420G, which has a banjo connector in the slave, therefore you need a hose with different threaded ends, similar to the rear brake flex hose on the etype. I had already been on the brakequip homepage, but found the navigation a little strange. Ill give them a call though, as they offer power steering hoses as well.
1963 OTS 880436
1963 OTS 880436
