#1 door hinges
Posted: Tue Mar 25, 2008 7:42 pm
Having just fitted the doors to my S2 OTS I have discovered some play in the hinges on both sides which was not apparent before I fastened the doors to them. I can lift the trailing edge of each door about 3-4mm.
As far as I can see it is possible to buy new hinges but not individual parts of hinges. Does this mean they are not repairable? I should be able to grind off the welds and remove the pins, but are there replaceable bushes inside the cast part of the hinge and is it possible to get new pins?
How much play is acceptable? Is there any play in new hinges?
Any advice would be greatly appreciated.
Dave.
Dave.
