Gearbox spring
Thim
Norway
#1 Gearbox spring
Post by Thim » Thu Aug 22, 2019 9:52 am
Hey, technical drawings shows the spring with only the underside supported on a rubber mount. Should there be one in both ends to prevent scratching? Pictures below.
Jaguar E-type s1, 1967 2+2. Under restoration by myself, slowly seeing the light at the end of the tunnel 👍
ETTony
#2 Re: Gearbox spring
Post by ETTony » Thu Aug 22, 2019 7:27 pm
Just the one spring seat at the base.
Tony in Devon
grimes6
#3 Re: Gearbox spring
Post by grimes6 » Thu Aug 22, 2019 10:50 pm
Strangely the parts book for the series 2 shows rubber seats on top and bottom. Maybe they changed the number for the later models ?
Greg
#4 Re: Gearbox spring
Post by abowie » Fri Aug 23, 2019 4:40 am
I've always put rubbers top and bottom. Supposed to stop the spring rattling.
#5 Re: Gearbox spring
Post by PeterCrespin » Fri Aug 23, 2019 6:08 pm
NVH: Noise, bad vibes and harshness. If it’s not your night. all of these can easily happen to any man thoughtlessly bouncing heavy weight on a rubber. Ask the Americans.
