#1 Dynamo conversion
Posted: Sun Sep 15, 2019 11:46 am
by lyons
Can I add to the topic below as I am about to carry out a similar conversion
Can someone who has done this, let me know if there is any advantage in buying/using the dummy control box with fuse or altering the standard RB340 control box on a positive earth car to suit.
Similarly is a smaller pulley worth having when carrying this out.
#2 Re: Dynamo conversion
Posted: Thu Sep 19, 2019 7:29 am
by Peter27
I have done this on a +ve earth car. Smaller pulley not necessary in my opinion. Personally I would fit the dummy regulator - it is an easy job. Slightly more tricky is fitting the relay behind the dash but you should be OK if you take your time and follow the instructions carefully.
#3 Re: Dynamo conversion
Posted: Sun Sep 22, 2019 2:39 pm
by lyons
Thanks Peter for your reply.
I was beginning to think that all was lost.
Reason for post was that I was trying to save unwanted expense on items not really required as part of this conversion.
