#1 Help S2 Manual gearbox problem
Posted: Tue Oct 01, 2019 11:48 am
I’m tyding up my 1969 S2, water circuit already done and front suspension refurbishment shortly on the way.
Meanwhile I’m having some problems with the gearbox for which I need your help.
Third gear cannot be engaged from time to time and when this happens i cannot alternatively go into 4th nor second without heavy grinding. Rest of gears goes reasonably well, it is only, and not always, when i go from second to third. Fourth to third is ok too! I recenctly changed gearbox oil and put SAE90 but to no avail.
I guess my options are (from hopefully cheaper to dearer):
- try with some other gbox oil to see if that helps
- take the gbox out and mend whatever it is
- look for a seconhand/rebuilt suitable gbox (wonder if XJs can be used?)
- go for a full monty and get a 5 gear box (it will help my 3.55 diff too)
Can you please advice me in assesing what could be the problem with my box and what would be your recommendation?
Unfortunately money is somehow object!
