The windscreen on my car is showing plenty of age-related marks, particularly noticeable are scratches following the arc of the driver's side wiper. Polarised lenses cuts them out during dry weather, but in the rain it's a different problem.
When the wipers pass over the scratches, they either keep missing the water in the grooves or not shifting it all. On a semi-wet screen in light rain, the screen has chance to dry in between wipes and clears completely, but when the rain is harder, the grooves seem to retain the moisture more. You can see them when there's condensation on the windscreen or during heavy rain:
The windscreen and wipers otherwise work well usually, shift water just fine, and the screen has plenty of Rain-X on. Tried removing the Rain-X at one point and seeing if that made any different, which it did not.
Things have improved slightly with a new wiper blade (I only replaced them last year!
Is this sort of thing possible to rectify, and if so, can anyone recommend any professionals who might be able help (for a reasonable fee!)
