In theory it would be good for someone like Autoglass to fit the screen. When I wanted a screen fitted 2 weeks ago I was treated by total unenthusiasm by everyone I rang. They are all too busy fitting bonded screens for insurance companies.
I ended up doing it myself. Never done it before. It took 2 hours s for most of it then some fiddling for the side chromes.
The secret is to have a new soft rubber (C O Baines £25), a small supply of petroleum jelly, a windscreen fitting hook £12.
https://www.ebay.co.uk/itm/NEW-Gunson-7 ... SwNoBdq9Lt)
I reused my original top and bottom strips, the rubber insert was straight forward too with the fitting tool.
The rubber goes around the aperture on the car, tap in in. Vaseline around the outer rubber lip in preparation for the glass. You can also put Vaseline in the window groove to help the glass slip around.
Then you place the screen on the bottom rubber and slowly waggle it so it gradually drops in the groove. You can use the hook tool to help it in. You will soon see the importance of the Vaseline.
Keep the windscreen central to the car. More the 2mm off and you will find one edge is easy to get in the rubber, the other will be impossible as it is too far over.
Once the glass goes in so far, no adjustment side to side is possible, so keep it central.
The glass may look like it is too wide. It wont be, as it goes in, it fits the hole.
Once the bottom of the glass is more or less in, work it the rubber in around the side, hooking the rubber lip over the glass gradually. You may need to support the glass with your hand from the inside a bit to stop it falling through in the early stages.
Eventually you will be on the window top section.
Never let the metal tool touch the glass.
The finishing strips are easier. Push the bottom od a strip into its rubber groove over a few inches. Hook the rubber in on the top of the strip. Do the same on the other side of the strip. Then you can just work along the length pulling the rubber over gently with the hook tool as you go. Watch centralisation again otherwise you will have a gap at one end when you fit the chrome sides.
You are now ready to bond in the side chromes. Use automotive body sealer from your local motor factors for £5 a tube. You need one tube and a corking gun. Be sure to check the widescreen Rubber lip will hold the pouter edge of the side chrome.
You may like to clamp it into place whist the sealer drys over 12 hours at least. Wear gloves, it does not come off skin easily.
Watch this video.
James
