#1 Churchill J17 tool dimensions
Posted: Tue Oct 29, 2019 6:37 pm
by ysmalkie
Hello,
I am looking for the J17 tool dimensions. Anyone has one and could measure it up?
Tadek
#2 Re: Churchill J17 tool dimensions
Posted: Tue Oct 29, 2019 7:45 pm
by norman m. macleod
Hi Tadek,
I have detailed drawing of that tool. I can e-mail it to you if you wish...…. E-mail me on
norman_m_macleod@iinet.net.au and confirm if you still need it. By the way, that tool can be purchased from Rob Beere in UK for about GBP90.00 or so...…
Kind regards,
Norman
#3 Re: Churchill J17 tool dimensions
Posted: Wed Oct 30, 2019 9:48 am
Or AFAIK it can be hired from the Jaguar Enthusiasts Club
#4 Re: Churchill J17 tool dimensions
Posted: Wed Oct 30, 2019 8:15 pm
Not my work so no guarantee.
#5 Re: Churchill J17 tool dimensions
Posted: Fri Nov 01, 2019 3:46 pm
by ysmalkie
Norman, Andrew, many thanks.
I compared the 2 drawings and they differ slightly with the critical dimensions. After round of to 1/100mm it looks as follows:
Norman's drawing translated to mm would be: 73.98 / 79.22 mm
Andrew: 74.10 / 79.20 mm +- 0.05mm
Another measurement I found on JL: 74.09 / 79.36 mm
I wonder where the differences come from.
I have never used this tool before - I presume the larger dimension is the one that actually settles the rope seal??
Tadek
#6 Re: Churchill J17 tool dimensions
Posted: Fri Nov 01, 2019 9:09 pm
It might be just conversion from imperial to metric. As I said I didn't make that image; I'm a jackdaw and collect everything I see and file it away for later use.
I do have access to an original sizing tool although it is not at my house.
If you need let me know and I can measure it with a metric vernier for you next week.
PS looking again at my picture I'm wondering whether the 2 critical sizes are in fact 2.900" and 3.100" (close to the 74.1 and 79.2 mm dimensions)
#7 Re: Churchill J17 tool dimensions
Posted: Sat Nov 02, 2019 1:45 pm
by Doug Buchan
"I have never used this tool before - I presume the larger dimension is the one that actually settles the rope seal??"
Hello Tadek,
You are correct. The first and smaller diameter is the tunnel bore guide followed by the chamfered ramp to final sizing. The tool undersizes the seal slightly. I have both Zelenda and Churchill variants if you need to verify sizes. (Imperial only sorry). I believe there is a thread on JL where a few of us posted the dimensions.
Doug
#8 Re: Churchill J17 tool dimensions
Posted: Sat Nov 02, 2019 4:30 pm
by ysmalkie
I could not find the thread on JL :-( Would you have a link to it by any chance?
Do you have a micrometer you could measure it with? Any ("" or mm) format is fine..
Help is much appreciated, I prefer to do one to the right size..
Many thanks,
Tadek
#9 Re: Churchill J17 tool dimensions
Posted: Sat Nov 02, 2019 5:02 pm
by Doug Buchan
Tadek,
Here is one of the threads however the dimensions listed aren't complete.
I will get to my tools in a day or so and measure them for you.
https://forums.jag-lovers.com/t/e-type- ... ion/120358
Regards, Doug
#10 Re: Churchill J17 tool dimensions
Posted: Sat Nov 02, 2019 9:28 pm
Quoting Doug:
"My Zelenda J17B measures 3.1194
A crank I have measures 3.1252 so the tool undersizes the
seal by .0058"
That makes sense.
#11 Re: Churchill J17 tool dimensions
Posted: Sun Nov 03, 2019 3:46 pm
by Geoff Green
Confirming measurements. Churchill J17 small diameter 2.92 inches 74.1 mm with this diameter 1 7/8 inches 47 mm with a 1mm 45 degree chamfer at the end. The midpoint between small and large diameters is 3/8 inch 9mm chamfer of abut 15 degrees then the large diameter 3.12 inches 79.2 mm with this diameter for a distance of 1 1/4 inches 32 mm.
#12 Re: Churchill J17 tool dimensions
Posted: Sun Nov 03, 2019 9:13 pm
by ysmalkie
Many thanks all,
I would presume than that 3.1195 - 3.12 sounds optimal.
Thanks for all help!
Tadek
#13 Re: Churchill J17 tool dimensions
Posted: Wed Nov 06, 2019 8:22 pm
by ysmalkie
Done :-)
My machinist was not happy with the fact I insisted on a 0.0004 tolerance..
But, here it is:
Many thanks for help!
