#1 Oil Filter sealing ring dimensions
Posted: Sun Jan 12, 2020 8:13 pm
by Jasper013
Would anyone happen to know the dimensions of the oil filter head/ filter canister sealing ring?
The OEM filter kits that SNG supply come with two sealing rings and I just want to make sure I'm using the correct one!
Both rings have the same circumference and same thickness, but one is slightly wider/ deeper than the other.
Any reason for two different rings being supplied? Or is it a case of 'use the one that fits the best' :smile:
Have looked through the tech data etc but cant find the info.
Thanks in advance.
#2 Re: Oil Filter sealing ring dimensions
Posted: Sun Jan 12, 2020 10:06 pm
Hi Paul..see similar topic below...filter o ring...Steve
#3 Re: Oil Filter sealing ring dimensions
Posted: Sun Jan 12, 2020 11:09 pm
by chrisfell
On my car the fat one won’t fit. The thin one seals just fine.
#4 Re: Oil Filter sealing ring dimensions
Posted: Mon Jan 13, 2020 9:29 pm
by Jasper013
mgcjag wrote: ↑
Thanks Steve.
Had spotted that thread. I'm sure its the thinner one I've always fitted before.
#5 Re: Oil Filter sealing ring dimensions
Posted: Mon Jan 13, 2020 9:34 pm
by Jasper013
chrisfell wrote: ↑
Thanks. That's what I've found previously as well.
Getting ready to crawl under and unleash the black stuff (think at best, I've only ever managed to capture about 85% of the oil, rest ends up on me, the floor ……... :lol: ).
