Stem seals or not?? Help please
#1 Stem seals or not?? Help please
Post by malcolm » Tue Feb 25, 2020 7:02 pm
I'm posting a question I raised on someone else's thread as a separate topic here.
My car HAD stem seals, but after a head rebuild, came back without. I was told "don't need them thumping up and down if you do the head properly" I should say it was a reputable builder, which Angus Moss uses, so I have no reason as such to doubt this. But it does seem a standard to fit them - for example, Rob Beere fits them.
What are the views on this? And can seals be fitted after the event easily, or is it a major job?
Thanks!
#2 Re: Stem seals or not?? Help please
Post by abowie » Tue Feb 25, 2020 8:00 pm
We always fit them, and why wouldn't you?
Problem is to fit modern seals that actually work properly you need to cut a groove in the valve guide which in practice involves fitting new guides. So if this isn't done they don't fit.
1954Etype
#3 Re: Stem seals or not?? Help please
Post by 1954Etype » Tue Feb 25, 2020 8:20 pm
Malcolm, who rebuilt your engine?
Angus 67 FHC 1E33656
61 OTS 875047
#4 Re: Stem seals or not?? Help please
Post by malcolm » Wed Feb 26, 2020 9:02 am
I'll pm you Angus
