#1 SU carb blockage?
Posted: Thu Jan 16, 2020 1:22 pm
by Malc
My car won’t start! It has been laid up for a few years while I did some work on it but when I came to start it, it wouldn’t. I think I have traced to problem to the carbs in that there appears to be a blockage and they are not getting petrol. The pump is fine and the fuel line is fine and petrol is being pumped when it is disconnected at the carbs. However as soon as the fuel line is connected, the pump stops. If I empty the fuel filter bowl, it fills about a centimetre, then the pump stops. If I turn the engine over, the fuel filter bowl remains half empty. So I assume there must be a blockage at the carbs - I assume that some crud has got in, although I am surprised that causes a fuel shortage to all three carbs. Anyone got any other theories?
I assume the only solution is to remove the carbs and clean them, and it appears the ‘easiest’ way, (and I use the word advisedly), is to take them off with the manifold. However can anyone advise me if there is an easier way to clear a blockage, i.e. without having to take the carbs off - can they be cleaned in situ? Many thanks.
#2 Re: SU carb blockage?
Posted: Thu Jan 16, 2020 1:37 pm
by Robbiee
Hi Malc
Simplest start is to remove the top of each float chamber and check for sticking needle valves that stop the fuel flowing in from the supply (usually as the chamber fills and a float lifts), they can stick
Give em a clean and maybe replace and try again
(No need to remove the carbs from the car to do this)
Robbi
#3 Re: SU carb blockage?
Posted: Thu Jan 16, 2020 1:42 pm
by tinworm
I was typing a similar fix myself and was beaten to it by Robee
#4 Re: SU carb blockage?
Posted: Thu Jan 16, 2020 1:51 pm
Hi Malc...where the banjo bolt screws into each fuel bowl lid there is a small cone shape metal gauze filter inside each one....also re check your main glass filter ...most replacement filters work in a reverse direction meaning dirt dosnt collect visably in the glass bowl but hidden inside the filter element....Steve
#5 Re: SU carb blockage?
Posted: Thu Jan 16, 2020 2:09 pm
As Steve has said..... and, if water has collected in the bottom of the tank, it will have been pumped through to the filter element in the glass bowl, and experience has shown that this "blinds" it . I should take the filter element out altogether, and then see if the bowl fills properly
#6 Re: SU carb blockage?
Posted: Thu Jan 16, 2020 3:01 pm
by malcolm
I'd go along with the needle valves in the float chambers. Mine stuck the other way so fuel kept flooding. Although maybe odd that all three should stick? An easy first check to make though.
#7 Re: SU carb blockage?
Posted: Thu Jan 16, 2020 5:00 pm
by Robbiee
I agree but worth an easy quick check!
#8 Re: SU carb blockage?
Posted: Fri Jan 17, 2020 11:14 am
by Malc
Thanks everyone for your advice. I am away now for a week (Iceland! My partner said she wanted some winter sun - I’m not sure Iceland is what she meant...) so won’t be able to try it all out until my return but I shall let you know the outcome.
#9 Re: SU carb blockage?
Posted: Fri Jan 17, 2020 5:10 pm
by rfs1957
Make sure you know how the float bowls breathe (via specially-shaped washers under the banjos) before you do too much around the float-bowl cover area.
You might yet be looking at a pump problem ........ it sounds like it will move fuel as long as there is no resistance.
I've never had this happen to me but believe an electrically-dodgy fuel-pump might exhibit this laziness.
I would check the fuel pressure on the exit from the pump, if done intelligently and safely, i.e. with the addition of a long piece of petrol pipe, you will soon judge whether the pump can sustain a consistent jet against a finger that is partially blocking the end.
(Ed - now expect someone to remind you that you shouldn't smoke whilst doing this.)
#10 Re: SU carb blockage?
Posted: Sun Jan 19, 2020 9:11 am
by cooper66
I had the same issue after the complete rebuild of the car. My pump was running but no petrol arrived to the filter, I took a seringue, plugged it on the pipe after the filter and vaccumed in order to have the pump properly feeded. If the petrol filter is not full it is a pump issue / fuel lines / filter issue not the carbs. One stupid remark but it happened to me, enough petrol in the tank ?
Then once your filter is full, if you still do not have any petrol to the carbs it is, as said previously, the float chamber needles most probably.
#11 Re: SU carb blockage?
Posted: Mon Jan 20, 2020 2:46 pm
by rfs1957
A correctly functioning SU pump does not require priming, it should work and produce a suck even when dry.
Otherwise, every time you ran out of petrol you would need to re-prime it.
#12 Re: SU carb blockage?
Posted: Tue Feb 25, 2020 4:19 pm
by Malc
Problem solved although I’m not really sure why! I took the carbs to bits but apart from the pistons being a bit dirty, all seemed good. I put new HT leads and plugs in and it started. The HT lead to the coil was loose so that probably didn’t help but I drove it without problem about 30 miles to a specialist for a once over and MOT (passed!) and they said all was well so who knows what the problem was - maybe an airlock in the fuel feed. Nice to have the car back on the road after five years!
