Anyone got a spare section of Windscreen Trim BD20562 ?
rfs1957
#1 Anyone got a spare section of Windscreen Trim BD20562 ?
Post by rfs1957 » Sat May 23, 2020 11:11 am
Prompted by the excitement of perhaps finding a solution
viewtopic.php?f=3&t=15896
and
viewtopic.php?f=2&t=15408&hilit=chromers
to my hood trim quandry, my thoughts wandered to another bright-work issue, viz the lower windscreen trim piece BD20562.
For reasons I can't quite grasp, and am afraid to adventure into (wrong side trims ? oddly-shaped scuttle ?), the two different chrome trims I have used were always just a little too short overall, and I was left with one of the holes in the ends just visible, despite everything else - windscreen included - going together fine.
If I get the trims de-chromed I can graft an extra section in easily enough, but if anyone has a scrap or damaged one lying around and would post me a 6" off-cut it would make life easier ?
Jeremy
#2 Re: Anyone got a spare section of Windscreen Trim BD20562 ?
Post by Jeremy » Sat May 23, 2020 1:58 pm
Rory, that is odd. Might it be you have a FHC upper chrome trim piece there?
Jeremy
1967 S1 4.2 FHC
rfs1957
#3 Re: Anyone got a spare section of Windscreen Trim BD20562 ?
Post by rfs1957 » Sat May 23, 2020 4:28 pm
Don't think so, it was very like the one that was on the car previously, both were a tad short - they fit, but you end up with one hole that is not quite covered by the ear of the side-trim.
Only an idiot would notice but .... follow my gaze.
It's really only 1/4" longer between the holes I need, but if it were 1" longer then it would actually make it easier to fit as there is just that bit more tucked behind the side trims.
