#1 Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 11:21 am
by Mich7920
Hi all,
Could somebody confirm me the value ?
I found 56lb/ft into a previous message but the forumer wasn't sure.
I don't find in the service manual.
Mich
#2 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 11:33 am
Hi Mich...service manual page B8 shows 54ftlb this was revised in a service bulletin...note engine numbers
#3 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 12:05 pm
by Mich7920
Steve,
I know this for the nuts but I would like the torque for the studs
Mich
#4 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 3:30 pm
Hi Mich.....as far as im aware the studs are not torqued ....they should be screwed in fully and tight to the bottom of the cleaned out threaded hole.....if there are torque figures im sure someone will let us know....Steve
#5 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 4:37 pm
by Mich7920
Thanks Steve.
Wait and see
#6 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 5:15 pm
by malcolm
I was told (by someone who knows far better than I)(although that's not hard
) that you just tighten them by hand then pinch them up. No torque setting, don't overtighten.
#7 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Fri Jan 24, 2020 10:58 pm
malcolm wrote: ↑Fri Jan 24, 2020 5:15 pm
This is correct. We put a generous amount of stud sealant on the bottom thread and then just screw them in finger tight. Obviously they need to be fully inserted down to the block face.
If you consider that the stud pulls against the block threads and stretches as you torque the nuts up, so acting like a spring, it makes it easier to understand.
#8 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sat Jan 25, 2020 9:01 am
by Mich7920
Thanks Malcolm and Andrew
#9 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sat Jan 25, 2020 10:04 am
by malcolm
abowie wrote: ↑Fri Jan 24, 2020 10:58 pm
Bloody hell! I got a technical thing right! That's a first.
#10 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sat Jan 25, 2020 1:36 pm
by 1954Etype
Don’t forget the copper washers.
#11 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sun Jan 26, 2020 6:51 pm
Hi Angus....what copper washers?
#12 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sun Jan 26, 2020 7:24 pm
#13 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sun Jan 26, 2020 8:02 pm
by 1954Etype
The 5/16 ones that go on the studs pointing down.
#14 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sun Jan 26, 2020 8:04 pm
by Mich7920
No I don't forget them.
thanks Angus
#15 Re: Tighten the cylinder block studs ( plain and dowel )
Posted: Sun Jan 26, 2020 10:26 pm
Ah....ok front studs into timing cover....Steve
