#1 Water/Bleed Pipe S3
Posted: Thu Jan 30, 2020 5:35 pm
by Neil Duke
Hi,me again,there are two small pipes,going from the inlet manifolds,to either side of the header tank,one broke off,as soon as I touched it.what is the easiest way to change them?Drill them out?Heat?Are new ones available,or just a bit of tube?Best way to secure them?
Thanks for looking.
#2 Re: Water/Bleed Pipe S3
Posted: Fri Jan 31, 2020 3:55 am
by rossco_j
Hello Neil,
I may have had a similar problem...Drilled & tapped for a new BSP barb. Replaced with a new section of hose. Hope the photos help.
#3 Re: Water/Bleed Pipe S3
Posted: Fri Jan 31, 2020 6:37 am
by Neil Duke
Magic,thanks for that.
