Washer bottle rubber replacement
lyons
#1 Washer bottle rubber replacement
Post by lyons » Sat Nov 02, 2019 5:20 pm
The rubbers that hold my glass washer bottle in place have perished with age, so the bottle rattles over every bump in the road.
As the frame is in excellent powder coated condition I need to replace. Surely someone has already replaced theirs and if so what did you use and what was the source.
Ta.
#2 Re: Washer bottle rubber replacement
Post by abowie » Sat Nov 02, 2019 9:17 pm
Various options but most require you to remove and split the square frame and then rivet it back into place.
I used double wall heat shrink. Others have used correctly sized rubber. IIRC someone found a rubber U channel with a cross section that worked well. Also consider replacing the rubber strip at the bottom. I used thin neoprene rubber from an old wetsuit.
#3 Re: Washer bottle rubber replacement
Post by rswaffie » Sun Nov 03, 2019 7:38 pm
ETTony
#4 Re: Washer bottle rubber replacement
Post by ETTony » Thu Dec 19, 2019 8:21 pm
I used upholstery strapping. The type used for seats with a limited stretch. Managed a good colour match too. Was only in 2” widths , so cut down. Worked on my S1 plastic reservoir. :P
Tony in Devon
SpeedieJag
#5 Re: Washer bottle rubber replacement
Post by SpeedieJag » Thu Dec 19, 2019 8:39 pm
This might work - I have been using a wrap-around electrical heat shrink tubing that can be applied to a wire (or in this case the metal strap) while it is in place. The shrink-wrap has an adhesive edge which adheres to itself after application.
In this instance, if you cut some pieces of rubber or some other material to produce the needed thickness, apply the shrink wrap tubing and then give it some heat; this should shrink down and look good. It's worth a try. The product is called Zippertubing (photo attached), available online and comes in different widths.
Good luck and report back,
James
James
1965 E-Type S1 OTS
2020 F-Type R Coupe
poofacio
#6 Re: Washer bottle rubber replacement
Post by poofacio » Wed Feb 19, 2020 6:22 pm
If it's any help the following from Hill top Products (01942 723101 - UK) is perfect for the rubbers. It is a double wall heat shrink and looks as if it will never shrink enough but it does!
Heavy wall heat shrink size 20/6 adhesive lined black HRHW
HRHW-20/6-ADH-o-STK Black.
You won't get a nearer match to the original.
61 RHD OBL DHC
61 flat floor DHC
61 FHC
63 FHC
66 FHC (QUAD LIGHTS)
Mich7920
#7 n othert solution
Post by Mich7920 » Wed Feb 19, 2020 10:12 pm
Michel
