#1 3.8 seat frame colour
Posted: Sat Feb 15, 2020 6:42 am
by ollieoscarsid
Can anyone help with a colour for the seat frames on a 3.8? I can’t find anything in the knowledge base. Mine were a kind of dove grey. Thanks. Chris.
#2 Re: 3.8 seat frame colour
Posted: Sat Feb 15, 2020 7:23 am
Primer colour. Doesn't matter; you can't see them.
#3 Re: 3.8 seat frame colour
Posted: Sat Feb 15, 2020 9:00 am
by noli383
Chris,
Yep, BS381C-694 Dove Grey is the colour I used - perfect match. Incidentally I believe the factory only painted the lower area which is visible under the seat cushion & underside of the seat if removed. The “vertical” backrest behind the moquette etc. was left raw steel .... well, that’s what I found when I removed the trim on mine. I suspect this is factory correct as I also found the body number in crayon on the backside of the leather panels. Of course, I chose to paint the whole shell prior to re-trimming.
#4 Re: 3.8 seat frame colour
Posted: Sat Feb 15, 2020 9:54 am
by andrewh
Is this Dove Grey the same colour as the soft top frames can anyone confirm?
#5 Re: 3.8 seat frame colour
Posted: Sat Feb 15, 2020 3:28 pm
Yes, a British Standard colour.
#6 Re: 3.8 seat frame colour
Posted: Sat Feb 15, 2020 3:30 pm
by andrewh
thanks David. I thought they looked the same colour.
#7 Re: 3.8 seat frame colour
Posted: Sat Feb 15, 2020 6:37 pm
by ollieoscarsid
Thank you gents, colour looks super. To the paint shop in the morning.
#8 Re: 3.8 seat frame colour
Posted: Mon Feb 17, 2020 10:30 am
by MarkRado
noli383 wrote: ↑Sat Feb 15, 2020 9:00 am
Noli, could you post some photos you have taken during dismantling? Originality is always interesting, even if one does not always follow this path.
#9 Re: 3.8 seat frame colour
Posted: Mon Feb 17, 2020 3:49 pm
by rswaffie
#10 Re: 3.8 seat frame colour
Posted: Tue Feb 18, 2020 5:09 am
by MarkRado
Thank you Richard, perfect documentation!
#11 Re: 3.8 seat frame colour
Posted: Tue Feb 18, 2020 7:15 am
by rswaffie
No problem. There’s quite a few more if you need them - I photographed the entire strip down as I went along.
#12 Re: 3.8 seat frame colour
Posted: Wed Feb 19, 2020 5:40 am
by MarkRado
Yes please! Thank you
