Intermittent rattle under cam cover
JMW2310
#1 Intermittent rattle under cam cover
Post by JMW2310 » Sun Mar 01, 2020 7:45 pm
I have a 1967 Series1 4.2l. On a recent run from Sussex to the West Country I got a load rattle which sounded like it was coming from under one of the cam covers. It could only be heard at low revs. When I reved the engine it appeared to go away. It appears to have cleared up now but I am keen to establish the cause in case it is serious. Any suggestions welcome.
Tom W
#2 Re: Intermittent rattle under cam cover
Post by Tom W » Sun Mar 01, 2020 9:04 pm
What frequency was the noise? Does it change with RPM? The guides the tappets run it can come loose, then they get clouted by the cam. Several people sell hold down kits.
Tom
1970 S2 FHC
#3 Re: Intermittent rattle under cam cover
Post by abowie » Sun Mar 01, 2020 9:30 pm
Firstly I would tighten the timing chain and see if the rattle recurs.
pmansson
Sweden
#4 Re: Intermittent rattle under cam cover
Post by pmansson » Mon Mar 09, 2020 6:04 pm
Agreed. I had a rattle between 1600-2200. Tightening the upper chain sorted that problem.
#5 Re: Intermittent rattle under cam cover
Post by PeterCrespin » Tue Mar 10, 2020 8:22 pm
JMW2310 wrote: ↑
Which cover?
JMW2310
#6 Re: Intermittent rattle under cam cover
Post by JMW2310 » Sat Mar 28, 2020 7:49 am
Tom W wrote: ↑
Hi Tom, sorry for the slow response! The noise is a consistent rattle. It is more noticeable when idling that when at higher revs. It really only seams to happen when I go on a long journey.
JMW2310
#7 Re: Intermittent rattle under cam cover
Post by JMW2310 » Sat Mar 28, 2020 7:52 am
abowie wrote: ↑
Thanks Andrew, I’ll try this first.
Tom W
#8 Re: Intermittent rattle under cam cover
Post by Tom W » Sat Mar 28, 2020 9:05 am
If it’s a constant rattling that doesn’t change frequency as the revs change, then it’s unlikely to be something rotating in the engine. I’d look for something loose in the engine bay that only resonates at certain speeds.
Tom
1970 S2 FHC
