#1 S3 charging/alternator concerns
Posted: Fri Apr 17, 2020 3:43 am
Hi chaps, hope everyone is ok.
After finally sorting out running issues (I'll update that thread shortly), on first test drive the ignition light came on and battery voltage on the voltmeter was in the red.
Checked voltage with multimeter across the battery terminals = 12.xx and gradually falling. I noticed the red warning light below the oil pressure light was also illuminated. After increasing RPM to around 1500, I was getting over 13V but ignition light still on. That's as much as I did that day as it was getting late.
Next day, started up, ignition light on and charging at idle. The red light below oil pressure light not on.
Spent a couple of days searching posts here, analysing wiring diagrams and workshop manual to no avail unfortunately. Looking at my pictures, can anyone identify if the alternator looks original? Workshop manual and other posts suggesting there should be a voltage regulator near the battery....there isn't one on this car!
There are 2 terminals on the alternator. One terminal has a small blue wire (exciter maybe?). I noticed that when the concern is present, there is ~1.5V here. When no concern, charging voltage is present. Both belts are tight as are alternator connections and main engine earth strap.
So, my main questions:
1. Does the alternator seem original?
2. Are there any other installation locations for the voltage regualtor? Or, could it not have one?
3. Is that blue wire the alternator feed/exciter?
4. What is the red light below the oil pressure light?
Many thanks in advance,
Matt
Matt
