#1 In take manifold / thermostat housing issue
Posted: Mon May 18, 2020 6:40 pm
Hi All
I’m just changing from strombergs to SU’s and it’s proving to be a bit more complicated than it should be! :-)
The manifold has a small triangle hole nest to the main hole that leads to the thermostat housing .(pic below)
But the thermostat housing from the stromberg set up did not, I was assured by a guy from the jag shop (independent advice) that they were the same and I did not need to change it but they are definitely different .so did they change half way through ?
I bought a replacement from Sng part no.C 28212 but that’s the same as the one I had from the strombergs.
The only thing I could find on their site was a thermostat housing gasket with the triangle cut but as of tonight they have not got back to me with what the difference is .
Any help would much appreciated as I have a mechanic waiting to come and set up the carbs and the sun is out!!
Thank you
Grant
Thank you
Grant
