#1 Fuel level warning light and sender
Posted: Mon May 18, 2020 7:31 pm
by swindler
Hi all
chapter 56 of my lockdown tinkering...
My fuel gauge works well with an accurate reading, but the low level warning lamp in the speedo is now permanently lit with the occasional flicker. It was temperamental for some time.
Is my problem with the sender unit?
Cheers!
#2 Re: Fuel level warning light and sender
Posted: Wed Jun 03, 2020 12:28 pm
by swindler
any tips on repairing the fuel level light (permanently lit) when the fuel gauge is working fine?
#3 Re: Fuel level warning light and sender
Posted: Wed Jun 03, 2020 12:35 pm
by chrisfell
I found this too. My solution was to extract the unit from the tank and cleanup the contacts. Problem solved. Another lister (either here or on J-L) had a sender that was too worn to repair this way. His solution was a replacement.
#4 Re: Fuel level warning light and sender
Posted: Wed Jun 03, 2020 2:32 pm
by swindler
Cheers - i'll give that a try
#5 Re: Fuel level warning light and sender
Posted: Wed Jun 03, 2020 4:59 pm
by Tom W
I had this problem when I first got my car. Turned out it was a wiring fault, with the connector for the warning light shorting on the tank where it connects to the sensor. I’m not sure if the 3.8 is the same. It would be worth disconnecting the lead and checking the light goes off first. If it doesn’t, you have a wiring fault, not a sensor fault.
