#1 heater box seal
Posted: Fri May 22, 2020 8:24 pm
by rossbraithwaite
There is a foam ring that seals between the heater box and the manifold that feeds it with fresh air on the bonnet; should this foam seal be mounted on the heater box or the manifold. Although there doesn't seem to be a great deal of adjustment in the location of either seal face are there any tips for checking the gap between heater box and manifold?
Thanks,
Ross
#2 Re: heater box seal
Posted: Fri May 22, 2020 10:07 pm
It is glued onto the underside of the manifold.
It's not uncommon for the foam to be a bit thick.
Align it so that it looks good on the manifold when the bonnet is open.
#3 Re: heater box seal
Posted: Sat May 23, 2020 4:17 am
by Geoff Allam
To check the clearance use a bit of plasticine, play-doh, or any other squishy material that holds it’s shape.
#4 Re: heater box seal
Posted: Sat May 23, 2020 7:29 pm
by rossbraithwaite
Thanks both
