Handbrake cable fixing
tim wood
#1 Handbrake cable fixing
Post by tim wood » Tue May 26, 2020 6:07 pm
My handbrake cable has been rubbing on the prop shaft at the rear end of the tunnel. This caused a frightful noise making me think the gearbox was on its way out.
On having a good look the cable has been tied to the tunnel side with a piece of locking wire which subsequently broke hence the rubbing.
I can’t see how the cable should be fixed, all I have are 2 small holes in the tunnel side where if exits the bulkhead. Should a fixing bracket or similar be here?
Thoughts appreciated.
Tim
288gto
Russia
#2 Re: Handbrake cable fixing
Post by 288gto » Tue May 26, 2020 6:30 pm
Hi Tim,
You should have an oval shaped bracket spot welded to the n/a rear of the transmission tunnel with an oval grommet in it. The cable passes through this. My car is up in the air at the moment, I'll take a pic and post it for you if that helps.
#3 Re: Handbrake cable fixing
Post by 1954Etype » Tue May 26, 2020 6:36 pm
Depends on how early the car is. The early ones had a spring that held the cable away. Later on, there was an oval with a grommet that the cable passes through.
tim wood
#4 Re: Handbrake cable fixing
Post by tim wood » Tue May 26, 2020 6:40 pm
Thanks Simon, a photo would be useful.
Angus, mine is a 1968 car
#5 Re: Handbrake cable fixing
Post by mgcjag » Tue May 26, 2020 6:46 pm
Hi Tim...see post no37..from factory fit viewtopic.php?f=4&t=2007&p=113032&hilit ... et#p113032
tim wood
#6 Re: Handbrake cable fixing
Post by tim wood » Tue May 26, 2020 7:04 pm
Thanks Steve, you are a mine of information!
That bracket is missing on mine so I will make one up & the grommet seems easy to obtain.
Thanks to all
Tim
#7 Re: Handbrake cable fixing
Post by Gfhug » Wed May 27, 2020 8:17 am
Tim, for what it’s worth on my S2 OTS project there was a small piece of foam on the propshaft tunnel next to that bracket. As though to stop the handbrake cable knocking against the tunnel. Whether original or not :shrug:
