Under body protection
PAN4213
#1 Under body protection
Post by PAN4213 » Tue Jun 16, 2020 8:15 am
Dear all,
looking at applying suitable protective coating to underside of body and in wheel arches etc.
I have WAXOYLE but i think thats more suited to box areas and cavities.
Was proposing to use 'SCHUTZ' , a flexible 'rubberised' coating.'
Is this OK or is there a better alternative?
cheers
1969 4.2 Series 2 US import being refurbed.
S2, 2+2, 1969
#2 Re: Under body protection
Post by rswaffie » Tue Jun 16, 2020 8:23 am
I had U-Pol Raptor applied to mine, tinted to match the paint colour. It has a slight textured look, but this can be reduced or increased depending on what you want.
The prep and application need to be done to suppliers spec to make sure it provides the long lasting protection. If it isn’t, it loses the benefits over other types of underseal.
PAN4213
#3 Re: Under body protection
Post by PAN4213 » Tue Jun 16, 2020 8:34 am
many thanks
will look up this material..
S2, 2+2, 1969
paulsco
#4 Re: Under body protection
Post by paulsco » Tue Jun 16, 2020 9:14 am
I used Dinitrol on mine as I did on my 340 many years ago and it is still holding up.
https://www.dinitroldirect.com/product/ ... gIUWvD_BwE
eddiecross
#5 Re: Under body protection
Post by eddiecross » Tue Jun 16, 2020 5:29 pm
This site is pretty good for stocking a good range of paints/waxes etc. Pretty informative too. I've used the Epoxy chassis paint which was excellent although a bit too glossy.
https://www.rust.co.uk/product/cat/wax- ... ng-kits-26
67 FHC
