I wondered if some of you would have a look around your oil-filter / air-filter / engine frame areas and help me firm up my coil-mounting issue.
I had made brackets that sat the coil on the long diagonal round tube, but that didn't work.
So now I'm having another stab.
I've mocked up motor and engine frame, this shot shows the RH engine frame in the right place relative to the engine, oil-filter, air-filter tubes, etc - please, is there anything missing that I'm going to get snarled up with ? !
I've not put the steering column in because I believe I'm way clear of it.
This is where I'm hoping to tuck it away.
Are there any maintenance access issues I've not considered ? Getting the oil filter out won't be as easy but removing the air-filter canister ought to solve this.
All and any comments most welcome.
