Hi... my PO had disabled and removed the compressor for the factory installed AC in my 1970 E... several wires are just dead ended, some have been spliced with different colored wires making tracing wires down and figuring out what where they go a bit of a challenge... I have removed / pulled what I believe is the wiring loom for the AC back to the firewall (it has the heat shield resistor in the middle of it) ... I am now working on removing the two relays associated with the AC unit... the Over Ride Relay and the AC compressor relay... is there any functionality that I am missing that removing these from the car will result in a failure of? I have yet to get under the dash to trace these wires back to their origins... any thing I should be looking for there?
Thx
Bob B
Removing AC Relay and Over Ride Relay
Topic author - Posts: 26
#1 Removing AC Relay and Over Ride Relay
1970 S2 OTS
1963 TR-4 (owned since 1980 under going frame off restoration)
2001 330 CIC
2001 330 CIC
