Accelerator peddle and throttle lever
#1 Accelerator peddle and throttle lever
Can you buy the half bush inserts pressed into the Accelerator peddle and the throttle lever. I have about 2” of play before the slack is taken up. Or can you build them up again with a bit of welding.
- Attachments
- 81BBC7DD-53CC-4C42-97A1-5B852EC9CAD0.jpeg (33.24 KiB) Viewed 1689 times
Tony (E typed)
Tony
Tony
#2 Re: Accelerator peddle and throttle lever
Tony : what are the inserts made of, and how are they retained within the pedal and link ? I was wondering whether I could turn you a pair up on the lathe, or as you say, reinstate the worn area with weld?
#3 Re: Accelerator peddle and throttle lever
Hi Christopher,
The inserts are some sort of metal but I think they are welded in. Thinking building them would be the best option and file down the shoulders to fit better.
Tony
Tony
Tony (E typed)
Tony
Tony
