Changing the clutch check list
Grant
#1 Changing the clutch check list
Post by Grant » Thu Oct 15, 2020 8:19 pm
Good evening all,
I have had a look on here ,but their are apparently 110 posts on here titled “changing the clutch “ and I’ve not found what I’m looking for which is a list of others things I should change , I’ve never done this before and I’m doing it with a mechanic friend but he has never done a jag before.
So is there a list anywhere on her or does any body have any recommendations? I do not want to rebuild the whole car but as the engine will be out I do not want to miss any thins I should of changed.
Thank you in advance as always
Grant
It’s a series 2 ots lhd from the USA now on Su’s
Series 2 OTS LHD
#2 Re: Changing the clutch check list
Post by mgcjag » Thu Oct 15, 2020 8:32 pm
Hi Grant......3 piece clutch.....cover/plate/release bearing.....spigot bearing in the end of the crankshaft.....whilst your doing it check the engine/ gearbox mounts....Steve
Grant
#3 Re: Changing the clutch check list
Post by Grant » Thu Oct 15, 2020 8:36 pm
Thank you Steve , that’s perfect , out of interest do you buy it as a whole unit bolt out bolt in or do you rebuild the one that’s in there? Normally
Series 2 OTS LHD
Mich7920
#4 Re: Changing the clutch check list
Post by Mich7920 » Thu Oct 15, 2020 8:53 pm
Change for new one, it's not a big price and it's really more secur.
Buy a set Cluch / release bearing it's preferable to not buy them separeted
Mich
Michel
Grant
#5 Re: Changing the clutch check list
Post by Grant » Thu Oct 15, 2020 9:36 pm
Thank you Mich much appreciated
I will speak
To Sng tomorrow
Series 2 OTS LHD
#6 Re: Changing the clutch check list
Post by mgcjag » Thu Oct 15, 2020 9:50 pm
Double check that the release bearing is correct when you reconnect gearbox to engine by just ensureing clutch fork is in the correct position......also worth checking rear gearbox oil seal...is it leaking.....Steve
Grant
#7 Re: Changing the clutch check list
Post by Grant » Fri Oct 16, 2020 6:20 am
Hi Steve ,
Ok , will do
Thanks again ,
Grant
Series 2 OTS LHD
Gerry
#8 Re: Changing the clutch check list
Post by Gerry » Fri Oct 16, 2020 1:16 pm
Hi Grant,be aware that there are a lot of bad throw out bearings out there,you could end up doing the clutch job twice!On some the carbon bonding does not hold on others the carbon disintegrates?
Regards Gerry 62 Ots Ontario Canada.
Grant
#9 Re: Changing the clutch check list
Post by Grant » Fri Oct 16, 2020 7:46 pm
Ok Gerry , I will give it a good look but I’m buying from sng Barrett so hopefully should be up to scratch, .
Thank you
Grant
Series 2 OTS LHD
