#1 Faulty clutch master cylinder
Posted: Sat Oct 17, 2020 11:18 am
Good Morning All,
My name is Chris. I seem to have a bit of a problem with my clutch. It is on an early 3.8 FHC. I recently replaced the master cylinder on the clutch. The replacement part was genuine Gerling part. I replaced and bled system. After test drive, the clutch was playing up again. I re-bled the system as I could see air bubbles coming up in the reservoir. I had a look at the Slave cylinder where there was some slight moisture so decided to replace Slave cylinder too. Having done that system was re-bled. Following further test drive, the clutch played up again. When pumping the clutch air bubbles appeared in reservoir. No loss of fluid. Clutch is difficult to engage. I can feel the gear box engaging, but when lifting the clutch, there is no response. The gear box is a standard Moss box. I can only guess that it is a faulty Master cylinder. Using Dott 4 brake and clutch fluid. If anyone has any thoughts, please let me know. Thanks Chris.
