#1 Heater control valve removal , hopefully!
Posted: Wed Oct 21, 2020 6:13 pm
by Grant
Hi All ,
I’m just in the process of stripping my engine bay for paint but cannot get the heater control valve to move, the spacer it’s on spins round the pipe and the pipe moves in the bulk head but I can’t even twist the heater control valve, have I missed something or is it just seized on from old age?
Thank you in advance as always
Grant
S2 lhd ots
#2 Re: Heater control valve removal , hopefully!
Posted: Wed Oct 21, 2020 6:36 pm
by Grant
Hi , I’ve just managed to find some more on here having the same problem, so it seems like it’s just brute force and ignorance. Unless anyone has found a way a better way of freeing it off .
Grant
#3 Re: Heater control valve removal , hopefully!
Posted: Wed Oct 21, 2020 7:02 pm
The valve seals onto the pipe with a rubber seal which is compressed between the valve and the spacer.
Yours has probably just fossilised. Enough rotation force should break it but you want to be careful you don't snap off the pipe.
A bit of judicious heat might help.
#4 Re: Heater control valve removal , hopefully!
Posted: Wed Oct 21, 2020 8:02 pm
by Grant
Hi Andrew
Yes, I’m
Going to try a few kettles of boiling water on it
Tomorrow,
I will let you know how I get on ,
Thank you
#5 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 5:06 am
I was thinking more of propane or oxy acetylene. But maybe that's just me...
#6 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 6:53 am
by Mich7920
Or heater gun.
Beware to not twested the iron pipe.
I don't think 100° is enought to remove it
#7 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 6:56 am
by Grant
Morning Andrew and Mich ,
I was just a little nervous of using a flame that close to the bulk head , I will have a go today and let you know how I get on ,
thank you
Grant
#8 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 7:17 am
by Mich7920
No flame with an electric heat gun
#9 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 10:13 am
by Grant
Hi Mich
Yes that’s a good idea thank youn
#10 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 11:16 am
by MSM
Hi Grant
Assuming the heater valve is to be replaced, judicious use of a junior hacksaw to split the body of the valve may be worth a try if you can get in there. You need to be careful not to nick the pipe though.
#11 Re: Heater control valve removal , hopefully!
Posted: Thu Oct 22, 2020 7:08 pm
by Richardhealey
Hi Grant,
I faced the same issue and a ‘little’ brute force of a flat head screwdriver between spacer and the valve freed mine. I think turing the valve body itself helped too.
I think a build up of calc and the rubber olive welding itself to the tube is the cause of the reluctance.
Hope is goes well!
Cheers,
Rich
#12 Re: Heater control valve removal , hopefully!
Posted: Mon Oct 26, 2020 7:40 am
by Grant
Hi Guys
Thank you for your replies, at this stage I’ve decided to leave it ,I do not want to open another can of worms at the moment, but I will let you know how I get on when I come back to it ,
Thank you all for your replies
Grant
