As you can see from the picture ,one of the four bolts that hold the rear engine/gearbox mount has a stripped captive nut. Just noticed it loose....tightened it and it never made it to even snug before that sinking feeling of a spinning bolt ( the bolt is fine )
So How the heck do I fix this ? the nut is inside the frame and inaccessible as near as I can see and it wiggles a bit.
Try to tap it too the next size? ( not promising with a wiggly nut )
Try to drill it all out and install a "rivet nut" ?
Either way ,its going to be yet another character building challenge.
Any suggestions or insights would be much appreciated
