#1 Hepolite Ring Set # 2555
Posted: Tue Dec 08, 2020 1:47 am
by mxke
I was digging thru some parts I have and came across this ring set.
Would these be for a 3.4 litre engine?
Thanks,
Mike
#2 Re: Hepolite Ring Set # 2555
Posted: Sat Dec 12, 2020 4:26 pm
by mxke
Someone must know!
#3 Re: Hepolite Ring Set # 2555
Posted: Sat Dec 12, 2020 5:28 pm
by bitsobrits
That bore is consistent with both the 3.4 and 2.4 liter versions of the XK engine. But as to ring thickness and count, and therefore compatibility with specific pistons, I think you will need to find some Hepolite documentation to give you a definitive answer as to which specific application they are for.
#4 Re: Hepolite Ring Set # 2555
Posted: Sat Dec 12, 2020 5:32 pm
by paulsco
Hi Mike,
All I can tell you from my Mk2 manual is that 3.2677 is the size of the cylinder bores of the 2.4 and 3.4 Mk2.
The 3.8 is 3.4252.
Hepolite are not standard fit pistons, at least not on the Mk2, Brico is.
#5 Re: Hepolite Ring Set # 2555
Posted: Sat Dec 12, 2020 5:36 pm
by paulsco
Sorry Steve; you answered this while I was still typing
#6 Re: Hepolite Ring Set # 2555
Posted: Sat Dec 12, 2020 5:50 pm
by mxke
Thank you!
Mike
