Next I have a query regarding fitting the filter head to the block. The block has three hole at the bottom where the housing only has two with the centre one missing. This filter housing has a spin on conversion which I took off to make sure it was not hiding a bolt hole. Will this be ok with the centre bottom bolt missing.
Has anyone else fitted an oil warning light. I am converting oil gauge to non electric and I was thinking of fitting a warning light as well. I do not like relying on an electric type gauge. I am also missing the parts between the the gearstick and the box (I think there are two main parts) Does anyone know of a reasonable source apart from new for these parts. Over £200 new or £110 plus on Ebay each. We are a long way off yet but is it ok to fit 185 65 15 and not 185 70 15 tyres simply because of cost and choice .
