#1 matching numbers?
Posted: Sun Jan 10, 2021 11:21 pm
by alfred
Just a dumb question: should the engine number and the cyl head number match? I had an interested buyer look at my 68 2+2 and he said my cyl number was different so not original to the car.
thanks for the help.
#2 Re: matching numbers?
Posted: Mon Jan 11, 2021 5:55 am
by PeterCrespin
They should match. where present, although cylinder heads stopped being painted and numbered in the later sixties.
#3 Re: matching numbers?
Posted: Mon Jan 11, 2021 8:45 am
This thread gives detailes from Jaguar hetitage trust of from what engine numbers the head stamo was ommited http://forum.etypeuk.com/viewtopic.php? ... cf#p110905
#4 Re: matching numbers?
Posted: Mon Jan 11, 2021 1:34 pm
by Robbiee
I thought that the block number is the important match ...cylinder heads could be easily replaced and therefore wouldn’t have an engine number stamped
#5 Re: matching numbers?
Posted: Mon Jan 11, 2021 4:16 pm
by alfred
thanks, that cleared things up nicely.
Alfred
#6 Re: matching numbers?
Posted: Mon Jan 11, 2021 4:56 pm
by Philk
Robbiee wrote: ↑
Ideally, Block, Cylinder Head, Crankshaft and Flywheel should all have the same numbers on them.... Unsurprisingly, the latter two are not often available . If you ever have your engine reconditioned get these photographed when it is stripped down - a really nice thing to add to the provenance of the car.
#7 Re: matching numbers?
Posted: Mon Jan 11, 2021 6:07 pm
by Robbiee
Yes...mine has everything but the flywheel stamped! I was rather delighted to see the engine number on the crank !
#8 Re: matching numbers?
Posted: Mon Jan 11, 2021 6:26 pm
I saw a post on FB recently that showed a gearbox mount plate with the body number stamped in it....Steve
