#1 Brake master Cylinder Leak. Options?
Posted: Thu Jan 14, 2021 7:43 pm
Hi there,
Just when I thought i was out of the woods with the cooling system refresh...
67 S1. Brake master cylinder leaking from the piston onto the floor.
These are the steps/options. Comments welcome.
Strip out the master cylinder and piston and inspect the bore. If pitted, replace with a new m/c (about £200).
If the bore is ok, I have the rebuild kit including the reaction assembly. I have a spare old m/c (had a S2 with the same problem) in case I need parts or anything goes awol
Next is whether I go on to replace the servo unit while I'm working. No obvious leaks (yet) but may be false economy to ignore. My preference is to replace as I tried rebuilding my S2 unit before and internal parts were broken and I don't want the hassle of replating the vacuum parts. Plus you seem to be able to get one for £180. Related question- are the cheaper replacements from David Manners and others ok for the price or should I step up to the £300-400 units. Not crazy about spending the extra if I don't need to.
Finally, if I replaced both, can I then replace the fluid with silicon with just a full bleed/purge of the rest of the system without any further stripping?
The car will be mainly in storage and I know the clock is ticking on mineral fluid life plus the mess it makes when it leaks.
All the best
Eddie
All the best
Eddie
